How to get a drive or reverse 12v signal
What are you trying to add power to or control? Reverse would be easy depending on load/amps, Drive would be more complicated. The DTR (trans range sensor) may be an option for a D sense, but its an input/monitored by the PCM and wouldn't be a power distribution point. Only R & D? would the lower ranges be an issue if triggered?
maxpower
06-24-2013 08:58 PM
