Ignition Problems F-150
Old 06-18-2005 | 12:22 AM
Frosty4422's Avatar
Default Ignition Problems F-150
I have a '93 F 150 4 X 4 5.0L I gave a Jeep owner a jump start the other night, left the truck running for about 15 minutes after. About an hour later I tried to start it. The first try to start it came close to turning over, then the second try nothing, just a clicking sound. Tried jump starting it and nothing, just a clicking sound again. Replaced the altenator today and still the same problem. Does anyone have a suggestions that might help me get my beauty back on the road.
Thanks for reading
Frosty
Old 06-20-2005 | 05:29 PM
cctxfish's Avatar
Default RE: Ignition Problems F-150
Might be a bad battery with a dead cell.
Old 06-21-2005 | 08:04 PM
tbolt's Avatar
Also check the solenoid and make sure you have a good ground.
Old 06-22-2005 | 04:29 AM
Lost's Avatar
Check all of your connections at the battery and solenoid. Clean them all with a wire brush, and make sure they're tight when you hook 'em all back up. Don't overtighten them though.
If that doesn't work, you probably shorted a cell in your battery when you jumped his pick-up.
And you'll have to replace the battery.
Miles
oso
07-29-2015 07:19 PM
n.alaska
11-08-2011 09:36 PM
bighueyy2k2
10-12-2006 10:58 PM
NicksMeanGT
11-01-2005 08:46 PM
84 SC
08-22-2005 05:36 PM
Quick Reply: Ignition Problems F-150
