Lights
Lights
Hello,
This is the problem I'm having on my 1996 F350 Deisel. With the headlight switch in the park light position, the park lights/tail lights come on. When the switch is pooled all the way out for the headlights, the park lights/tail lights turn off.
Left and Right turn flashers work. Hazard flashers work. Brake lights work. I have replaced the headlight switch but this did not correct the problem.
Can anyone help?
Thank you.
Can anyone help?
Thank you.
Shared grounds for heads/stop/park/tail. Multiple grounds as well, chance you might loose L/R together, doubt it. S/B,, ground left on the inner core support close to the fender area, right, on the inner fender area forward..
marty
12-05-2007 12:23 PM
marty
12-05-2007 12:22 PM
moonunitpurple
03-08-2007 09:51 AM
