Mis-Fire in Engine
Old 08-08-2007 | 07:35 AM
abrandon's Avatar
Default Mis-Fire in Engine
I have a 2003 F-250 5.4 and recently it just starting mis-Firing. I basically have a dead hole in onecylinder. However, there is no warning lights coming on in the dash so a basic scan will not tell me anything.It could be various things. plug, injector, coil, cam sensor, does anybody have any recommendations in where to start digging first?
Old 08-08-2007 | 07:46 AM
Use Common Sense's Avatar
Default RE: Mis-Fire in Engine
Does it do it when idling?If so, you can start by unhooking onecoil packat a time. If you have a bad plug/coil the bad on will show no change while good ones will cause the engine to run rough.
Old 08-08-2007 | 07:51 AM
abrandon's Avatar
Yes, it does mis-fire when idling. I think that is where I will start, Thanks!
Old 08-08-2007 | 11:14 AM
abrandon's Avatar
Checked coils, got lucky first one on the right easiest one to get to. pulled off coil and pulled plug, noticed a little moisture. Changed plug, working great now!
Old 08-08-2007 | 12:14 PM
Yep...Had that happen on my 00 Taurus. Applied dielectrical grease to the plug and aroung where the boot seats to the valve cover. No problems in the past 3 years...
screechv10
04-23-2013 09:05 AM
kenben
11-09-2009 07:41 AM
buster97
06-04-2009 02:54 PM
cobra65
12-06-2008 12:42 PM
slingshot37091
05-01-2007 03:55 AM
Quick Reply: Mis-Fire in Engine
