Motorcraft solid state electronic ignitionHELP!
I need help wiring this Ford ignition module. I want to install it on my 1960 T-Bird with the 430 engine. It has a Duraspark ii distributor. The only numbers on the ignition box are30 6 69. The yellow and red wire are seperate from the blue, black, brown wires. the The yellow has a male pin connector, and the blue has a female pin connector. any help will be very appreciated. thanks again.
17, 69, early, electronic, ford, ignition, install, module, modules, motercraft, motorcraft, solid, state, wier, wiring
