Need Throttle Position Sensor expertise
Old 07-02-2017 | 01:53 PM
KAP's Avatar
KAP
Default Need Throttle Position Sensor expertise
I have a 2009 E350 12 passenger van with the 5.4 engine. I've had intermittent TPS issues over the years and even had the entire throttle body replaced about 4 years ago.
The problem now is that the engine will suddenly go into limp mode, with the "wrench" light coming on. The code says a TPS issue. For a couple of years, I could disconnect the negative battery terminal and discharge the system, thus doing a "reset" on the computer and that would fix the problem, sometimes for over a year without having a single issue. But now the reset no longer works and the van goes into limp mode as soon as it starts to re-calibrate idle speed. Last night we got stranded on a lonely road, an hour from home, in a thunderstorm. Fun.
My question is, before I replace a TPS, which is more likely to be the culprit, the TPS on the throttle body or the one on the accelerator pedal?
Both are expensive, even for DIY, so I would hate to guess wrong.
Thanks for any help on this.
Old 08-20-2017 | 02:33 PM
Bill Harlow's Avatar
I'm having the exact same issue. Ive replaced that sensor 3 times in a year now
did you ever find out what it was
Old 08-20-2017 | 07:04 PM
KAP's Avatar
KAP
Bill,
My original code was a P2111, Throttle Actuator Control System - Stuck Open.
I replaced the TPS and no change. I then replaced the throttle body with a used one and again, no change.
I then replaced the accelerator pedal and sensor with a used one and no change still.
So finally I took it to the Ford dealership since I figured that they would be able to at least diagnose what the true problem was and then I could decide what to do about it.
Turns out I had two places where the wiring harness had become old and brittle and the voltage going to the throttle body TPS and/or actuator motor was too low.
Ford replaced a couple of wiring harness "pigtails" and charged me a $135 electrical tracing fee and $150 repair fee including parts and labor. Grand total was right at $300.00.
I made a video about it here:
Hope this helps.
Doyle
08-21-2017 07:02 AM
Ejectr
08-26-2009 09:58 AM
camperman
04-24-2008 04:21 PM
Mals
03-17-2008 01:56 PM
qcarver
09-30-2007 12:34 PM
