negative cable ford ranger
Old 03-15-2012 | 02:48 PM
CFord02's Avatar
Default negative cable ford ranger
I need to replace my negative cable on my 2002 ranger 3.0
can I simply run a new cable from my neg battery post to the ground on the engine? OR does the negative cable go other places also??
The complete harness from ford costs 116 dollars
Im aware of the wire running to the radiator cradle from the negative post on thr battery .
.. Im asking about the main negative cable with the terminal on it the runs from the battery .
Old 03-15-2012 | 03:57 PM
As long as you use the same gauge wire for the cable , you can connect it to any solid part of the engine. Make sure the other ground wires coming from the negative terminal have good clean connections also.
Old 03-15-2012 | 04:58 PM
CFord02's Avatar
So, I can REPLACE the current cable correct?
Old 03-15-2012 | 05:00 PM
CFord02's Avatar
What I mean is I will no longer need onls cable to batttery if i do this right?
Old 03-15-2012 | 06:54 PM
You do need a heavy gauge cable to handle the heavy current draw from the starter itself. The rest of the system doesn't require as much current as the starter.
Old 03-16-2012 | 07:46 PM
greasemark's Avatar
One thing I would recommend is to make sure that you carry the pigtails off the original cables from the body and frame back to the negative battery post. This prevents scores of hard to diagnose problems that you don't want.
teleman
10-25-2013 05:31 AM
newyorker
01-15-2013 06:52 PM
programguru
08-27-2009 12:16 AM
rlevy64614
08-07-2008 10:40 PM
jillofor
11-29-2006 04:28 PM
Quick Reply: negative cable ford ranger
