new starter, wires
Old 11-07-2008 | 04:45 PM
gdaitken's Avatar
Default new starter, wires
I just installed a new starter & wires in my '98 Expedition. It cranks well but does not start; seems like it's not getting fuel. Checked fuel shutoff; that's not it. Any ideas?
Old 11-08-2008 | 05:30 PM
techford's Avatar
Default RE: new starter, wires
Hi, Have you ever had any problem with your factory anti-theft system? Do you have any aftermarket system of that kind? When you put your key in the ignition to the ON position, when all the lights goes ON in the instrument cluster, does you anti-theft light goes off or it blinks rapidly?
Why did you changed these parts? Was the problem there before? Do you have the 4.6L or the 5.4L ?
You are gonna have to check if you have spark and fuel pressure. You might flood it by triing to start it. You should have a shraeder valve on the injector ramp, remove the cap, put your key ON and using a small screwdriver push the little spring, watch out fuel getting out pressurize.
Nic.
thegetupkid7609
06-22-2010 12:41 PM
90tonkatoy250
07-07-2009 08:56 PM
borg2offive
12-16-2008 09:47 PM
kraussy783
03-25-2007 02:37 AM
jdm
02-26-2006 08:38 PM
Quick Reply: new starter, wires
