No blower?!?
Old 06-23-2013 | 04:19 PM
Comanche5L's Avatar
Default No blower?!?
Hey guys ive been chasing a heater prob around and ran out of options. I have a 2007 E-250 van, and the blower fan stopped working months ago. Picked up another at the junk yard, put it in, and still nothing.
Tested the wires going to it (while running) and no power. Changed out the heater resister beside the blower under the hood and still nothing. Dont know where to go next and any help in the right direction would be greatly appreciated!!
Thanks, Justin
Old 07-29-2013 | 08:04 PM
go-part's Avatar
Former Sponsor
Have you checked the fuses and relays?
1997 ford e250 heater and a/c not working? - Yahoo! Answers
Old 08-01-2013 | 03:12 AM
GilbertF's Avatar
Does it have a blower relay? if so swap some relays in your box and see if that does it.
Old 08-01-2013 | 03:55 PM
One of the first things I would do is to apply voltage and ground to either of the motors and see if they run. If so,then check if there is any power at the blower motor switch, coming in and going out when turned on. Usually , there is a separate relay for hi speed and since you have neither hi or any other speed I would suspect the blower motor switch or the function switch (vent, A/C, floor, def etc.). You did check all the fuses ?
Old 08-05-2013 | 08:57 AM
vanessar's Avatar
At this point I say get a new one. Even if you fix it, it will get bad again..
ricknags
04-05-2019 02:39 PM
SFPD770
10-24-2006 06:28 PM
David Mason
05-27-2006 08:20 PM
daleh1
03-06-2006 08:46 AM
Deam
08-01-2004 06:20 PM
Quick Reply: No blower?!?
