patching transmission coolant lines E4OD
Old 08-16-2019 | 05:07 PM
petreussg's Avatar
Default patching transmission coolant lines E4OD
Hello,
I'm in the process of changing out my radiator and cannot get my transmission coolant lines off. The nuts holding it down are completely stripped.
Is there a process that can be used to patch the lines? Like cut it at a certain point and put a new fitting on it? If there is, I might just get an extra transmission cooler also while I'm at it.
I have a 91 F250 with an E4OD transmission.
Thanks!
Old 08-16-2019 | 06:54 PM
I have seen where the correct size hose that could handle high temp and was oil resistant (like fuel line hose) was inserted with double clamps and it held up quite well.
Old 08-18-2019 | 04:11 PM
petreussg's Avatar
Thanks!
I got the process now.
Really easy.
Cut, Flair, put on pressure hose, two clamps, and the needed fitting on the other end.
Bob Burton
10-21-2019 07:38 AM
PlorkZ
01-13-2018 05:29 PM
laidback
05-14-2012 02:00 PM
NH_USA
09-18-2011 02:10 PM
shredder1223
03-29-2008 12:10 PM
Quick Reply: patching transmission coolant lines E4OD
