Pioneer/Clarion nav radios
For a 2009 Escape, you will need the Xanavi/Clarion HDD Nav.
You will also need the following to complete the install assuming your car has SYNC:
Replacement Right side steering wheel control
Antenna Splitter
Extender Cable
Amplifer
Amplifier Harness
Procedure 1 & 2 Harness with Sync Pins (available from United Radio)
United Radio sells everything you need as a kit, and can also program the vehicle to your vehicle.
You will also need a new dash bezel that comes from the ford dealer.
Antenna Splitter
Extender Cable
Amplifer
Amplifier Harness
Ford sport trac radio
I have a 08 sport trac adrenalin. It does not have the navigation radio in it. It does have micro soft sync and blue tooth and 6 disk cd. I was wondering if I can put an 09 explorer ford navigation radio in it and will it work.. Ford dealer is absolutely no help...
You may be able to put an 09 radio in, but it's not meant to be put it that car and you may run into a lot of compatibility issues with SWC & Sync. Also the 09 will require an external amp.
I would recommend just putting the 08 Pioneer Nav in, like what would have came with the truck. All you'll need is an 8A2T-18K931 nav unit, Map, Antenna, and have the unit programmed to your vehicle.
Antenna Splitter
Extender Cable
Amplifer
Amplifier Harness
Antenna Splitter
Extender Cable
Amplifer
Amplifier Harness
We have 2 units on us right now. part numbers are AL1T-18k931-AE and CC3T-18k931-AA
2009, 2010, 2012, al1t18k931, car, cc3t18k931aa, clarion, escape, ford, navigation, oem, pioneer, programming, put, radio, reprogram, sport, trac
