powersteering box leaking
RE: powersteering box leaking
yes you can change the seal but when you buy the new seal you have to get the whole rebuilt kit. Take the pitman arm of there is a dust seal then the main seal use a small screw, screw it in the MIDDLE of the seal in the metal a few threads use sidecutters and pry it of to install find a deap socket that will fit over the splines, this will be you seal installer.
FreestarDriver
06-30-2011 07:44 AM
