probe will not idle after warmed up
Old 03-20-2006 | 09:30 PM
snjakeman21's Avatar
Default probe will not idle after warmed up
My probe will not idle once the engine has warmed up. It runs great when it is still cold, but once you drive it long enough for it to warm up, it cuts off at stops. It is a manual transmission. So long as you continue to give it gas it will run just fine. As you let off the gas and begin to slow down the check engine light comes on , if you give it gas it will go off, or if you stop it cuts off.
In the past this problem would only happen if the battery died and was jumped or was disconected then reattached. It would correct itself over a long nonstop trip (say 100 Interstate miles) and would not have another idle problem until the next dead battery. It has been this way for 4 years since I bought the car. Now the problem is starting to occur with out the battery issue. It still corrects itself if you take a long trip, but now starts back up again at spontanous times.
I hope Ive provided a pretty thorough description of the problem. It is aggravating keeping PRMs up in Nuetral at stops. Please any suggestions would help.
thanks stephen
thund3rchick3n
09-06-2011 05:02 PM
jmerriman
03-31-2006 03:08 PM
snjakeman21
03-29-2006 10:33 AM
bj87f150
11-03-2005 02:29 PM
bj87f150
11-03-2005 02:29 PM
