Right turn signal not working Transit 04
Old 09-17-2012 | 06:12 PM
Transit04's Avatar
Default Right turn signal not working Transit 04
The righ turn signal light does not work. I have tested everything I can think of. relays (under the steering wheel, the passenger side and to the left in engine compartment), fuses and contacts and of course light bulbs but still no light.
I can hear it click once in the relay in the engine compartment then it stops.
I have measured the power into the lever behind the steering wheel, everything ok.
Left turn signal works as it should.
I have also swapped the two relays in the engine compartment. Located left side under the main fusebox.
Hazard warning lights works.
What else can it be?
Can someone please help me with a wiring diagram or give me advice?
Old 09-18-2012 | 02:20 AM
Generally if the left side is working correctly, that would rule out the supply and the flasher. I would suspect one of two possibilities. One is the signal lite switch assy has an open contact or the wire from the right signal point from the switch to the right side has an open in it.
Old 09-18-2012 | 09:19 PM
greasemark's Avatar
There is a TSB that addresses exactly this problem; TSB12-7-12, which involves replacing the affected front T/S bulb and its socket. This is a common problem. While you're there, if it's under 3/36, you can get the PCM reflashed so the direct clutch in the transmision doesn't burn up. Or, if it's out of warranty, just wait until it does, then powertrain will cover it (5/60).
Just a thought.
Cheers!
mark
Old 09-21-2012 | 02:07 AM
JeanePittman's Avatar
Glowbug
01-28-2022 12:43 PM
tylyn
12-05-2010 09:46 AM
Dongo
12-28-2008 11:58 PM
ranchhorse
05-19-2008 05:08 PM
hmcgary
05-01-2008 01:30 PM
Quick Reply: Right turn signal not working Transit 04
