Rough idle and chugging at constant speed. Please help
Old 04-26-2011 | 04:02 PM
N9ZYE's Avatar
Default Rough idle and chugging at constant speed. Please help
Another new guy here in need of assistance. I bought a 2006 E-150 last week. It has the 4.6L V8 engine with 163,000 miles. I filled the gasoline tank and the van ran fine. I topped off yesterday with 9 gallons of gasoline and now the van chugs at idle and at constant speed. It seems to run smoother while accelerating. I checked to be sure the gas cap was tight. Does this sound like water in the gasoline? I didn’t find another post quite like the problem I am having.
On another note, neither Haynes nor Chilton’s list a DIY repair manual for this 2006 E150 van. Have I missed something in my search for a manual?
My apologies if this should have been posted in the Econoline E series forum.
Thanks,
Gary
Old 04-26-2011 | 06:36 PM
If you suspect your last load of fuel , the simplest thing is to try is a bottle of dri gas and see if it helps. It would be a good idea to change the fuel filter too, then you will at least know that has been done.
Old 04-26-2011 | 07:09 PM
way2old's Avatar
Do what hanky suggested and then have the PCM scanned with a scanner that can detect engine misfires. Mode $06 can indicate a cylinder misfire. Also if you are in a location where it has been raining (like where I live) water could be getting in the plug wells causuing a misfire. That would mean changing spark plugs and possibly coil boots.
Old 04-26-2011 | 08:42 PM
N9ZYE's Avatar
We have received a fair amount of rain here in Indianapolis. Thanks for the suggestions.
nuckleball5
10-16-2012 10:26 PM
mrkauphy
01-28-2012 05:42 AM
tacomagic
11-27-2009 04:13 PM
JTGrant1
04-14-2009 09:42 PM
wildcatFORD
02-11-2007 05:05 AM
