Rough Idle and P 0171 code
Old 03-20-2007 | 07:54 PM
jaycoward's Avatar
Default RE: Rough Idle and P 0171 code
There was a slight exhaust leak just ahead of the catalytic converter. I tightened it up, stopped the leak, but the car still stalls constantly and smells at a stop.
  #12
Old 03-20-2007 | 11:58 PM
goinstrong's Avatar
The leak could have fouled up the converter. You should remove it and check the convertor tubes for damage and/or blockage. If you shine light through one end you should see it fairly strong through the other whenlooking straight-on through.
  #13
Old 03-21-2007 | 01:27 AM
goinstrong's Avatar
Do an oil change and smell for gas in the old oil. This would be a sign of gasket or block damage. Gassy smell in your radiator is also a bad sign.
  #14
Old 03-21-2007 | 04:04 AM
rebelranger01's Avatar
check the wire to ayour O2 sensor on bank one maybe one has broken or come undone which would let the car think its lean on one and then way overfuel....which will clog your converter, maybe you even gto a bad O2
  #15
Old 03-21-2007 | 11:39 PM
jaycoward's Avatar
Oil smells ok and I don't really smell anything unusual in the antifreeze. I did trace the wires on the O2 and they look fine, no breaks etc. Another guy suggested it still may be a vacuum leak on the back side of the throttle body. He suggested placing a small hose on a propane tank, starting the engine and slowly open the valve on the tank just a bit and move it all around that throttle body and the attached vacuum lines. He said if the engine idles out smootly, I found the leak. Sound plausible?
  #16
Old 03-22-2007 | 02:56 AM
goinstrong's Avatar
Yeah. That will work - just don't let it suck too much propane for too long. If it does even out you've got it nailed. If not I'm going to say that I just don't trust the converter. Especially if there was a leak ahead of it. That tells me it could have had the time to pull a good amount of debris and dustinto it.
Sandman400
03-30-2013 01:46 PM
Olpapa
05-18-2008 04:22 PM
bmerlino
11-16-2007 09:39 AM
funkdoobiest
08-25-2006 03:09 AM
mcginnt
06-14-2006 01:56 PM
