rpm drop w/ ac or heat on
Old 03-04-2009 | 03:45 PM
ledbo8's Avatar
Default rpm drop w/ ac or heat on
02 sable w/ 3.0 sohc... once warm with the a/c or heat on the rpms flucuate by about 300-400 rpm. the idle air control checks good and was cleaned. i have checked all vacuum lines and all appear good. i would think if it were vacuum it would do it all the time but im no expert. can the compressor be causing this problem? any suggestions would be greatly appreciated as ive read about this problem before but ive never found any definitive results. Thanks!!
Use Common Sense
06-25-2016 02:30 PM
loz1970
09-27-2009 03:34 PM
glazier
01-08-2006 01:07 AM
glazier
01-05-2006 02:26 AM
cris4099
11-30-2005 02:30 PM
Quick Reply: rpm drop w/ ac or heat on
