Service Engine code --Next step?
service engine soon light is on (E150, 4.2, 01).
Got a readout at one of the major parts chain, their equipment stated code: P0304
cylinder 4 misfire condition.
Step 1: Pulled plugs and on inspection they all looked good. Since I had new, installed those.
Step 2: With volt/ohmeter tested plug wires. All readings were around 12 to 14 ohms.
Step 3:What to do............????/
Should I replace the coil pack? With only a volt/ohmeter, is there a way for me to check?
Additional comments.......engine starts very well, the only symptom I may be noticing is; there is a little shake, very slight, when pulling away from a stop. I tend to feel it at lower RPMs.
The coil pack is approximately $80. Have I presented sufficient information to support picking up a coil pack as my next step?
The van has been running very well, it has 134K miles on it. Doesn't seem to be near ready for the junkyard.
Any comments/questions/input?
Thanks in advance,
Doyle
Thanks in advance,
Doyle
RE: Service Engine code --Next step?
To test that coil.Swap itwith another cylinder and see if the code follows the coil. If it does, it's the coil. Check around for different prices. I can get 8 for 300 bucks off ebay that are genuine motorcraft.
eallan
10-28-2009 06:10 PM
