someone help please
Old 01-03-2010 | 08:47 PM
xxlarisalynnxx's Avatar
Default someone help please
does anyone know anything about probes? please let me know
Old 01-07-2010 | 07:24 PM
digital_diversion's Avatar
probes? don't aliens use them??
ask your question!
Old 01-08-2010 | 01:58 PM
JackEmHigh's Avatar
What kind of issue are you having?
Old 01-22-2010 | 10:30 PM
well we put new axles in like 3 weeks ago, and when u push on the gas it sounds like you can hear the axles spinning.......it didnt do that before we put the new ones in and we cant figure it out.......does anyone know what would cause this??
Old 01-23-2010 | 03:19 PM
what type of sound? metal on metal? growl? screech?
probes have front wheel drive transaxles.....is it standard or automatic? did you replace the axle seals? did they leak? have you looked? have you checked fluid/gear oil level?
jack the front end into the air and get under it while wheels are moving and try to pinpoint the source...(FOLLOW safety precautions when getting under a car while its running...block wheels..etc) if your not sure...take a large screwdriver and place it against your ear and metal tip on parts of car to try and pinpoint source...
more info needed........
Old 01-24-2010 | 01:47 PM
yeah it kinda sounds a little like metal on metal........its an automatic.......we just replaced the axles, like just the part that has the boot n stuff on........when we did it the fluids were ok.....................my only thing and i think this might be the problem....on the new axles we got they have this gear thing on but the old ones didnt...they are the same except for that gear....well we put them on anyways cause the gear thats on them was not in the way of anything for the most part...do you think that stuff could of shifted and now its rubbing something.............i really need to figure it out cause i dont have time to just rip everything apart cause of needing my car to drive to school and work....
Old 01-24-2010 | 10:15 PM
post a picture if you can...
gear thing? not enough info
Old 01-27-2010 | 11:59 AM
'99 Vicky's Avatar
Those gear things on the axles(CV shafts) are going to be the ABS sensor rings. Those rings may be rubbing on something with in the spindle mounts. My advice would be to jack up the car and get to a point where you can see these rings. If they are rubbing on something you will be able to see the damage on the "gear" teeth, if they are rubbing you will need to take the axles out and find out exactly what they are rubbing on. You may need to get CV Shafts that don't have the gear rings on them. One tip from a experienced "backyard" tinkerer, if the new parts don't look EXACTLY like the old parts you are taking out don't use them, go get the right part, and take the old parts to the parts house with you for comparison.
llazarus10
03-07-2011 05:33 PM
Aphotic
11-13-2008 03:46 PM
ford truck
11-10-2008 10:02 PM
ford truck
04-28-2007 09:42 PM
93 escort wagon
05-14-2006 12:01 AM
Quick Reply: someone help please
