Stalled shifting from park
Old 07-07-2013 | 12:29 PM
Steveromo's Avatar
Default Stalled shifting from park
2007 Freestyle automatic. Yesterday it twice stalled when shifting from park to drive and reverse. Outside temp was in 90's and AC was on full blast. Decided to shut AC off when starting and then turn on after driving a few minutes. Was Ok since but "check engine" has been lit since first stall. Seems ok now but don't want to ignore a potential issue. Any suggestions?
Old 07-07-2013 | 02:48 PM
One of the things you can do is to have the vehicle checked for any stored codes which might provide some direction. Many auto stores will check your vehicle for any stored codes at no charge to you.
Old 07-08-2013 | 08:50 PM
greasemark's Avatar
Get the codes read; anything (from TP to TACmotor not responding) will mean the throttle body is going out, which was classic for these.
Old 07-09-2013 | 02:10 PM
Steveromo's Avatar
Default Update
Thanks for replies. Since my post, I have used the vehicle for 8 short trips (5-25 minutes.) The "check engine" light went out after 4 trips. No problems since original stalling. Would error code still show up in diagnostic test? I would like to take a "wait and see" approach, maybe it was just an isolated misfire and maybe nothing else will occur. Is that a mistake? What would you suggest I do?
Old 07-09-2013 | 02:32 PM
The fact that the lite went out would signify the problem is no longer present (at this time). It could repeat and spoil your day. A free check of possible codes in the PCM, if any, could save you some trouble up the road and at least you could have some idea of which system was involved. Just think , you can do this at your leisure !
maxpower
06-24-2013 08:58 PM
01exp.
01-07-2009 07:25 PM
cindymac
03-24-2007 10:47 PM
cjc4x4
04-20-2006 04:22 PM
jcwilliamsjr
10-05-2005 10:57 PM
Quick Reply: Stalled shifting from park
