Steering Me Wrong
Old 09-26-2010 | 06:44 PM
vinnyinaz's Avatar
Default Steering Me Wrong
Hi,I've got a 1951 F1 pickup and the steering is downright SCARY!!! You're constantly fighting to keep it going in a straight line. When the truck is standing still and you turn the wheel, the front lifts. For instance, if you turn the wheel to the right, the left front fender seems to lift. The truck has the original straight axle.Does anyone have any suggestions short of putting in a whole new front end which I can't afford right now. Thanks.Vinny
Old 09-27-2010 | 06:14 AM
david paul's Avatar
Check king pins and bushings
Old 09-27-2010 | 09:46 AM
vinnyinaz's Avatar
Thanks David. I'll give that a try.
Vinny
Old 09-29-2010 | 06:51 PM
vinnyinaz's Avatar
I checked with my son and he said someone already replaced the kingpins. Could the steering box create the problem? Does anyone know if a rack and pinion can be put onto a straight axle. Not replacing the entire front end but just a rack and pinion. If so, rack and pinion from what car? Thanks.
Old 10-10-2010 | 07:08 PM
scott56ford@yahoo.com's Avatar
i have a 56 with 34 inch rail centers and used a 2003 crown victoria aluminum frount end it was bolt on and cost about 400 at junk yard hub to hub
jjessen
03-08-2019 03:13 PM
strider380
04-24-2007 04:44 PM
mmmahlstede
08-29-2005 01:12 AM
stableboy06
02-28-2005 07:23 PM
77fordhighboy
02-24-2005 03:14 AM
Quick Reply: Steering Me Wrong
