sway bar links
Old 02-11-2008 | 09:56 PM
lostneedhelp's Avatar
Default sway bar links
Hi I have a 92 Aerostar, and a 98 Explorer. On both the sway bar links broke what would cause this? And no I am not hitting curbs, pot holes, or going off road.When it happened on the Aerostar nothing else went wrong, but on the Explorer the c.v. axles went while I am replacing the axles I am also replacing the outer tie rod ends because they are bad also ball joints look good. What would cause sway bar links to break? Thank You and Have a Nice day.
Old 02-11-2008 | 10:12 PM
btexpress's Avatar
Default RE: sway bar links
The sway bar links are a very common failure on these vehicles, in my opinion it is due to the small diameter of the bolts. The replacements are a heavier, thicker design. If you live in a snow area, near a beach, or in the rust belt, this just aggravates the failure rate.
Old 02-12-2008 | 03:01 PM
Thanks for the answer I live in Jersey down the shore so I get snow and the ocean working on the rust and corrosion. Thanks again.
palmo10
10-29-2011 06:49 PM
captainriprap
05-31-2009 09:41 AM
Davetheslave
07-17-2007 05:05 PM
davej
10-19-2006 02:04 AM
91EXPLORER
07-25-2006 12:35 AM
