Sync 3, Navigation and touch screen went on the fritz
Old 09-10-2019 | 04:45 PM
dtsb's Avatar
Question Sync 3, Navigation and touch screen went on the fritz
2018 F-150 Lariat with Sync 3. The problem started last month. The connection with my iPhone7 began to drop. I would be on a phone call and the BT connection would drop, and I carried on the conversation through the phone's speaker/mic. Then, several seconds or maybe a minute later, the BT would connect on its own and the call would switch back to the truck's's speaker/mic.
Then, on a road trip, the red GPS icon came up on the screen when I was in Navigation. The touch screen also became unreliable and would lag -- touch to action would be delayed for a second to many seconds or not work at all.
Now, at times, if I am on Sirius, if I try to switch channels, it makes the button I pressed a programmed button for the station that I am currently listening to and now I have two of the same stations programmed.
I have reset the unit several times by pressing the power button and the right arrow. It seems to make the Nav work for a bit.
When I press the button on the steering wheel to activate the voice menu, it is buggy. Sometimes it works, other times the voice prompts are delayed, and if I am lucky enough to get past saying, "Find and address," the voice will cut in and out.
I was in the dealership and I set an appointment, but I am fearful of the cost of repair! Truck just went out of warranty, 42K mi. This all started happening before the 36K miles mark, so not sure what I will be able to get the dealership to do.
Any ideas on what might be broken?
I just performed system updates and it says the system is up to date.
Thanks.
dtsb
09-10-2019 01:23 PM
Tuscany
11-02-2017 12:10 PM
djalbrec
10-28-2017 09:53 AM
copper penny
04-30-2017 05:31 PM
