Tachometer installation in 2000 v6 Ford Ranger ? Which (-) 'green' tach lead 'pulse' wire ? Question
(This is a re-post due to incorrect year model in thread title)
2000 Ford Ranger, 3.0liter V6 Flex Fuel, Automatic, (No stock tach) - Tachometer installation question:
Hello,
I am trying to install an aftermarket (Autometer) tach in my 2000 For Ranger, 3.0v6 flex fuel.
I am trying to find the tach lead (Green wire) point of installation. On my older cars, I used the coil (-) wire, on my S10 I used the ECU (-) wire, but I know little about Fords (My first Ford truck) ....
So my question is, is there a 'stock' wire on the guage pod cluster that I can use (No stock tach on my truck), or which ECU / other wire would I splice ? PS, this is distributorless ignition.
Thanks !
This is a re-post ... I stated the wrong year model and could not edit it.
The Original Post Is Located Here:
https://www.fordforum.com/m_20752/tm.htm
(Incorrect year model - I know the trucks changed from 2000 to 2001 so I wanted to correct myself)
Hello,
Thanks !
RE: Tachometer installation in 2000 v6 Ford Ranger ? Which (-) 'green' tach lead 'pulse' wire ? Question
You'll need to add an aftermarket 'tach driver' for the distributorless ignition.... MSD offers one, and there's other vendors/products available as well...
http://www.msdignition.com/ignition_27_a_8913.htm
ORIGINAL: Hayapower
Ahhh very interesting .....
Thank you for the link!
[RESOLVED] - (Although, is there a 'stock' wire on the pod cluster (for use with pods' with a tach ???) ???
Thanks again,
'Later ...
Aftermarket Tachometer Installation / Hookup 2001 3.0 Liter v6 Ford Ranger (How to?Green Tach Wire?)
ballzach
02-19-2007 01:10 AM
