truck lost all power please help
Old 03-09-2009 | 05:35 PM
nateo's Avatar
Default truck lost all power please help
I have a 75 ford f-250 with a 460 and i went to change out the battery and the power cable grounded and the solenoid started to smoke so i replaced that and still have no power to lights wont even crank. so i jumped the new solenoid to drive it home and the radio didnt even come on but when i shut the truck off nothing worked after that please help
Old 03-09-2009 | 08:03 PM
Check the fusable link wires..
There a smaller wire leading off the solenoid that are 'designed' to burn if the system shorts out or jumped backwards ect... Hold the fuse link wire (think they were brown) and give them a tug, the insulation will/may stretch out and snap if the link wire is broken inside the wire covering, or you may be able to see evidence of heat/melting in the wire insulation indicating the link wire is toast....
Old 03-09-2009 | 09:02 PM
nateo's Avatar
thanks ill check it out!!!!!
Skylar McCoy
02-15-2012 07:52 AM
bernieb
02-07-2009 07:17 AM
jtr73
01-28-2009 08:49 PM
jetblue
02-04-2007 05:13 PM
jetblue
03-12-2006 12:35 AM
Quick Reply: truck lost all power please help
