turn signal nightmare
Working on my stepsons 95 crown vic. Turnsignals dont work at all, no dash light display or exterior light display. Hazards do work on dash and exterior . Have replaced multi function switch and lcm. Can get relay to intermittenly click in.Also blower motor doesnt work,but if I turn heater switch on the relay for the. turn signals stops clicking. Any ideas where to start looking next? also all other actions of the multi switch works no problems.
Make sure all the fuses are good. Sometimes there are poor connections at the fuse panel. It does sound like there is a poor ground connection. A good place to start would be check all the ground connections starting right at the battery and the sheet metal.Looking at them is not checking them they have to be loosened and retightened to make sure they are making good contact. Not sure if your vehicle has a separate flasher for the signal lights and separate flasher for the hazard lights. If so replace it.
Your owner's manual will tell you if it does. Check the fuse section.
ok thanks i will check grounds, that was a thought i had. the fuses are all good and i checked voltage into the fuse panel whivh was good at 12. it has all the relays in the lcm. so onto chasing the wiring nightmare with my diagram in hand. will post again after checking. thanks.
yeah probably so,but the car isnt worth there 80 dollars a hour . who knows how many hours they would have in it. im pretty good at electrical i just was hoping not to chase. i preffer to paint and do body work.
If you can get to the wire connection that feeds the blower motor, what happens if you separate them from the rest of the car and feed the motor a ground and 12 volts directly ? If the motor runs fine , now you know for sure there is a poor connection somewhere. Now you can verify the ground wire integrity and hot feed circuits. Usually ground wires are black and the hot wire to the motor is usually orange.
What do you think?
What do you think?
Glowbug
01-28-2022 12:43 PM
