Turn signals won't work
Old 12-18-2008 | 11:24 AM
ChuluotaBlackie's Avatar
Default Turn signals won't work
My turn signals won't work, inside on dash or outside, no clicking noise inside - I've checked fuze, it is ok. Emergency flashers work, brake lights work, headlights work. Not sure what to do next. Thanks - Melody
Old 12-18-2008 | 06:02 PM
way2old's Avatar
Default RE: Turn signals won't work
Kinda need year and model. I guess we can assume it is a Ford. It can be a flasher, switch, lighting module. Please post the year and model of vehicle. Thanks.
Old 12-18-2008 | 08:32 PM
Sorry - this forum stuff is all new to me! F250, turbo diesel, 2004, 4 wdr - Thanks
Old 12-19-2008 | 06:44 PM
way2old's Avatar
There is a flasher up above where your right knee would be. There is a small bracket there that has 2 relays in it. The bigger one is the flasher. Click here for a picture. This is from Autozone. They may have a diagram showing exactly where it is. Good luck and let us know if that fixws it, or if more help is needed.
Old 12-20-2008 | 07:14 AM
have not been able to locate that bracket/relay. I removed the access panel under steering column, and the are several relays in the fuze box, but I could not find the relays above the driver's right knee as you suggested.
what might i be doing wrong??
Old 12-20-2008 | 01:45 PM
way2old's Avatar
It is on a bracket and is installed with the relay on the top side. It will have a black cover on it. One side is just a little taller than the other. It is really hard to see. You just about have to lay on the floorboard and looh up under the dash area. It is not easy to get to. Hopefully the picture will show. If it does, the flasher is inAuxillary Relay Box 1. It is toward the center.
[IMG]local://upfiles/4125/57D4BAF47BCB45048A820BD7997C1697.gif[/IMG]
Old 12-22-2008 | 11:39 AM
Thank you - after 4 of us checking the fuse it turned out to be bad - we installed the new relay & still didn't have turn signals, so decided to replace the fuse anyway - I now have turn signals.
Thanks,
Melody
Old 12-22-2008 | 06:09 PM
way2old's Avatar
Good job staying with it. You may want to invest in a test light to check fuses with. They are fairly inexpensive and take the guesswork out of the blown fuse.
stevprin
07-15-2019 08:33 AM
Durr
10-08-2011 09:02 PM
CADOP
01-01-2011 05:58 PM
1bigfordlover2
09-17-2010 04:42 AM
Luke 22
01-27-2007 03:26 AM
Quick Reply: Turn signals won't work
