Window motor on 95 T-bird
Old 08-27-2006 | 02:29 AM
Davetheslave's Avatar
Default Window motor on 95 T-bird
The window motor on my 95 T-bird is not going up gets stuck half way up and if you push the switch and push the window with your hand it will go up. I am trying to replace the motor, but it is tight in there also do I have to remove the rivites, and do the passenger side and drivers side swap out can one be used for the other because if I get one at the junk yard probably passenger will of had less use. any help is greatly appreciated because the Hanes manual is not much help at all.
Old 08-27-2006 | 10:22 AM
94 4x4 ranger's Avatar
Default RE: Window motor on 95 T-bird
My parts book say's these window motor's are different.
rc10mm
01-02-2007 08:50 AM
SV6Mustang
12-15-2006 12:59 PM
Davetheslave
09-20-2006 12:39 PM
Davetheslave
09-01-2006 12:59 AM
Davetheslave
08-27-2006 10:24 AM
Quick Reply: Window motor on 95 T-bird
