Adjustable fuel pressure regulator
RE: Adjustable fuel pressure regulator
First of all I wonder why?
Secondly, your engine uses a fuel rail pressure sensor to control fuel pressure to the injectors, modulating the fuel pump output with current control. Even if you put an adjustable regulator on it, the PCM will control the fuel pump to the PSI it determines to be correct.
fl_hayseed
06-03-2011 10:18 AM
