High Performance Engine Kits for Ford
You can't go wrong purchasing our High Performance (HP) Engine Kits!
They include Pistons, Rings, Gaskets, Head Gasket, Main & Rod Bearings and more with additional options like rods and turbos! Our HP Kits are exclusive to us - you won't find them anywhere else!
We've done the work finding the parts that fit your engine, all you have to do is click or call to buy!
HP Engine Kits - Sport Compact
Engine Kits - Domestic
Web Ford Sport Compact: IPP
Web Ford Domestic: Flatlander Racing
Ph: (603) 378-0090
Ph: (603) 378-0090
High Performance Engine rebuild kits
I have also had great luck working with RPM Machine for performance parts. The guys really go out of their way to help build your project. If you are needing an engine rebuild kit I would give them a try as well. I needed a 331 stroker kit for my mustang and wasn't sure exactly what I was doing, Everyone else I called acted like I was bothering them with my questions about how to build it and what I had to do to make it work and RPM not only took the time to answer my questions but actually put together a estimated dyno build up for me to help make decisions on camshafts and compression ratio's and possible cylinder head combinations.
carid
12-22-2014 06:03 AM
Mister Pig
06-18-2014 11:21 AM
