1997 Explorer Oil Pan Gasket
From what I've heard.
As far as I know, No! Good question though. Maybe there is a Ford master tech on here who has figured something out. Same goes for the timing chain. If I were going to go to that much trouble, I would check the timing chain as well.
Thanks again.
ummm what kinda engine? there are 2 types for that year... is it the 5.0L or the 4.0L? and i have been able to yank the pan from my 1987 Crown Vic that is equipped with a 5.0L in it. the pan in my car is a double sump since it goes over the front crossmember. the way i did it was remove engine mount bolt on each side, lift engine, remove pan bolts, removed distributor, removed oil pump and pickup screen then get the oil pump shaft out. after that is out of the way, engine needs rotated to have bottom end(Crank) to clear the pan. also gonna take some adjusting of raising the engine to about its max tipping where rear is touching firewall.
