87 e150 fuel pump & speedometer die together
Old 08-08-2011 | 12:34 PM
joeyj1954's Avatar
Default 87 e150 fuel pump & speedometer die together
drove 100' and died. replaced fuel pump relay, no result. Hot wired frame pump, and upon driving found speedo inop .
Old 08-08-2011 | 02:54 PM
I'm not positive about any connection between the speedometer and the fuel pump(s), but I have seen where the driving gear on the trans tail shaft has become stripped and will no longer make the speedometer work on those 87's. If that is the case you can remove the driveshaft andrear tailshaft housing and replace the stripped gear . It's only held in place with a small spring clip. You will need to count the teeth on the gear that drives the speedometer cable so you get the correct nylon gear for the trans.
jozepy24
07-13-2019 06:21 AM
fordexpedition2006
04-21-2017 06:23 PM
Happy302
02-14-2013 11:51 AM
stoogesrule
02-23-2008 08:07 PM
