97 f150 4.2L Fuel problem
Old 07-02-2005 | 10:57 PM
rushman's Avatar
Default 97 f150 4.2L Fuel problem
Hi everyone, I need help bad with this one. I recently had to replace a bad rod and pulled the engine and when I put it back it won't start. The gas gets all the way to the pressure regulator and stops, I thought maybe the regulator was bad so I replaced it. No Luck. So I tried hooking up a vaccum line from a running car to the regulator still No Luck. The fuel rails are dry the gas will not go past the regulator Why? I have asked around but nobody knows! Also when I spray a little starting fluid in the throttle body it starts up for 10 or 15 seconds. So it seems to be just the problem of getting the fuel in the rails. It ran fine before it just had a rod knock. PLEASE HELP ME!! Thanks Brad
beam43
10-01-2013 04:06 PM
Greatwhite1983
08-06-2012 11:47 PM
alpopz2
07-11-2011 07:49 PM
cruckshank87
11-07-2009 02:16 AM
gwald
03-26-2006 02:09 AM
