Car won't stay running
Old 06-09-2005 | 07:35 PM
jkkay's Avatar
Default Car won't stay running
I have a 80 ford futura 2 door 6cly 4 speed car id# 0E93B187601 I have replace the Ing-Control Module, Cap, Rotor, Plugs, Wires, Coil & fuel filters.. The problem I'm having is the Car runs like a bat out of hell.. but if you let it just sit and run in the drive way for about 10 to 15 mins it will stop on its own.. and you can not start it again for about 1 to 2 hours.. it will crank but will not start. I get no spark after the car has shut off. the battery is good but. I check the Ing-Control Module after the car stops and it is not hot.. do you have any idea's what might be wrong with the car.. nobody here in town can find the problem. Only thing i have found that gets hot is the electic chock on the top of the carb. when you speed up the idel the chock on the carb gets hot. i don't know what else to check or do.. the car has only 70,000 miles on it
Thanks John
Old 06-10-2005 | 12:09 AM
truckpuller's Avatar
Default RE: Car won't stay running
The ING control module doesnt have to feel hot just for kicks i would change it and see if that fixes it and oh yea i have gotin bad ones that have failed after a week or so too.
Old 02-24-2021 | 04:39 PM
aron1142's Avatar
Does a 2001 ford exhibition 5.4 alt have a fuel pressure control module and where would it be
taurus25
12-25-2014 07:21 PM
cewill99
07-06-2012 09:04 PM
badgerfan7
04-21-2008 09:09 PM
golferguy
08-29-2006 11:37 AM
79Chero
08-20-2005 03:59 PM
