External Trans Oil Cooler Position before or after original radiator cooler
Old 04-23-2020 | 07:42 PM
petreussg's Avatar
Default External Trans Oil Cooler Position before or after original radiator cooler
Hello,
I have:
91 F250 351W
Last summer I bought and installed an extra transmission oil cooler (because it was cheap and I wanted a little project).
What is the best way to install these things? What I did was route oil from transmission into radiator cooler, then from radiator cooler to external cooler, and back to transmission. So it goes:
  1. Transmission
  2. Original Radiator Cooler
  3. External Cooler
  4. Transmission
Is that the best way, or is it better to reverse 2 and 3 like this:
  1. Transmission
  2. External Cooler
  3. Original Radiator Cooler
  4. Transmission
I'm probably going to be taking things apart this summer due to not liking the look of where I mounted it, so I'd like to re-install in the best way.
Thanks!
Old 04-24-2020 | 06:47 AM
How about this,
We would like to keep the trans operating temp as close to "operating temp " as possible.
If we choose the first path you mentioned the red temp should be in the area of 140-180 degrees F.
I never measured the temp of the fluid coming out of the rad cooler, but some vehicles did have a gauge showing the temp.
It probably would be a good idea to measure both set-ups and see which provides the best cooling.
Old 10-26-2020 | 11:13 AM
amesgang's Avatar
Default transmission cooler
You should go through the radiator first, then the cooler.
Originally Posted by petreussg
Hello,
I have:
91 F250 351W
  1. Transmission
  3. External Cooler
  4. Transmission
  1. Transmission
  2. External Cooler
  4. Transmission
Thanks!
99explorereddiebaur
04-05-2018 09:36 PM
jnmlucas
02-18-2008 07:33 AM
newyorker
12-27-2007 12:16 PM
adipainter
10-31-2007 09:09 AM
kerwinq
08-01-2006 12:28 AM
