f-550 axle removal
Old 12-27-2011 | 06:30 PM
rwracing's Avatar
Default f-550 axle removal
need help cant get left front axle out of 2006 f-550
Old 12-27-2011 | 06:54 PM
I believe you need to remove the front differential housing cover. Then rotate ring gear and remove the bolt that goes through the carrier assy ( 8 mm) and holds a block in place so the axles cannot move inward. Remove bolt, block and "C"washer on end of axle. Axle should be able to be removed now.
Old 12-27-2011 | 06:56 PM
rwracing's Avatar
thought that might be the case wanted to make sure first, thanks for the help.
klandon
10-02-2013 04:47 PM
socalocman03
07-05-2013 02:53 AM
WB9IIE
02-07-2011 09:15 PM
RobertM68
02-27-2008 06:35 PM
njnut
08-14-2006 11:04 PM
