help with my 2005 crown vic oil cooling hose replacement
hello i have a 2005 crown vic,i have leaking oil cooler hoses,new ones on the way,i have removed bolt from hose on radiater end with now problem,i have moved to oil filter end and the bolt head has been rounded off,can someone please suggest a way to remove this bolt without causeing myself alot of work.
thanks
thanks
They make a tool called turbo socket that has a reverse cut in it. The tighter it gets, the more it grabs. Or maybe the next smaller socket size can be tapped over the rounded portion and allow you to remove it. The following link has the sockets individually. Parts houses may loan you one also. Check the 4th one down.
Socket Sets - Turbo - Sockets - Grainger Industrial Supply
87 Royal Limey
05-18-2009 02:13 PM
