Problem with Door Ajar Button
Old 04-05-2012 | 06:56 PM
tammypeters's Avatar
Default Problem with Door Ajar Button
I have a 2001 Ford Expedition and the problem that I am having is the when I drive the the Door Ajar button is lit and make a beeping noise. When I stop my inside light and lights on my side mirrors stay on or either they go off and then come back on. Is there a way to disable the light until I can afford to get it fixed?
Thanks for any help
Old 04-12-2012 | 08:31 PM
David DjKahuna Nunez's Avatar
if you look in the owners manual there should be a code using ur seat belt and light switch to disable the chime noise in the mean time.. i dont know about the lights inside
Old 04-13-2012 | 06:27 PM
way2old's Avatar
Get some WD-40 or PB Blaster and spray the latches in the door. The door ajar switch is on the latch. Open and close the door a few times and the light will probably go oyt. Usually it is the drivers door that has the problem as it is used more. Good luck.
mike 96 ws6
09-25-2012 09:25 AM
mholder
10-03-2011 07:03 PM
Zapman
02-16-2009 07:29 PM
Mike11C
05-27-2007 03:14 PM
briterone
11-21-2006 11:51 PM
