1955 T-Bird Automatic Trans Fluid
Old 03-13-2008 | 09:09 AM
gcsmial's Avatar
Default 1955 T-Bird Automatic Trans Fluid
the 1955 Ford T-Bird documentation says to use Type "A" transmission fluid which is no longer available. I am in the process of of restoring the car and I am looking for advise on what transmission fluid is compatible with the clutches and valves of this original transmission. What fluid is best? What will work?
Old 01-04-2009 | 01:53 AM
goinstrong's Avatar
Default RE: 1955 T-Bird Automatic Trans Fluid
Type A may have been replaced by type "F". If you try any of that newer Dextron/Mercon crap you're likely to end up with headaches after a few miles.
Martin001
12-22-2015 04:16 PM
GaryR
01-09-2010 11:43 PM
royleexx
01-26-2009 03:15 AM
teausant
01-16-2009 10:24 AM
