Service light on Transit 04 2,0 L
Old 08-13-2012 | 06:57 PM
Transit04's Avatar
Default Service light on Transit 04 2,0 L
Hi,
I hope someone can help me with the following problem:
The service light ( Icon of a wrench) comes on when I start the car and the speedometer and the rpm meter are dead as long as this light is on.
After a while though it goes away and the speedometer and rpm meter comes to life.
In the manual it says that I can push the brake and the gas pedal in in about 15 seconds and then the light will flash and turn itself off, but this does not work.
What can be the problem?
Old 09-05-2012 | 11:43 AM
vipercarcom's Avatar
Default Reset service light indicator Ford Transit
The full procedure how to reset service light indicator Ford Transit. If you like to reset any maintenance oil light after an oil change. Or reset check engine light, airbag light, inspection key or insp errors when maint reqd, for Ford cars. Or any warning light for service reminder which appears on the display.
Reset service light indicator Ford Transit | Reset service light
tootsie
11-08-2006 01:52 PM
marklar81005
10-11-2006 02:00 PM
rascall142
09-16-2006 08:53 AM
Doyle
03-31-2006 01:18 AM
AbNormal27
02-24-2006 01:12 PM
