Sights 'N Sounds Post Video and Sound clips here. This forum is for video's pertaining to Ford's, Racing (Street/Strip), Interviews, and Off Topic.
1971 ford f100 ticking or lifter noise after replacing intake
Old 10-20-2019 | 06:59 PM
Cameron Choiniere's Avatar
Default 1971 ford f100 ticking or lifter noise after replacing intake
I have replaced the intake on my 390 fe engine which requires the removal of the valve covers rail and rods. Everything went nicely all of the rods are seated correctly and I torqued the four bold down in sequence up to the proper torque specs of 45 foot pounds. After getting everything together and timing the engine I started it and heard a loud noise that sounded like noisy lifters but it is so loud it is almost louder than the engine noise (it is straight pipped very loud). I did an oil change before I started it and it has never been low on oil I always keep up on maintenance. I also got me aluminum valve covers for it as well.
Old 10-20-2019 | 08:03 PM
Welcome to the site..
The pushrods can sometimes be different lengths, more so on rebuilt engines. When removing the rocker shafts, the push rods should be location matched, and top/bottom orientation as well. Sometimes when tightening the rockers shafts too quick, and a lifter/s have oil expanded, it can drive a valve into the top of piston, depending on the pistons.
With the covers off, manually roll the engine over to take the cams pressure off the bottom of the/each lifter. With your fingers you should be able to spin the push rods. If any of the pushrods are bent, it’ll show up fairly easy. Sometimes manifolds depending on who’s, won’t have enough bore clearance for the pushrods..
You could always run the engine with the covers off and check for shaft/rocker oil delivery
Old 10-21-2019 | 07:04 AM
so at tdc I measure from the top of the rod to the lifter and they should all be the same distance away?
FordGalaxie885
06-16-2013 08:20 PM
rpalm
03-04-2011 04:20 PM
bigbsc
10-28-2007 04:52 PM
78ford
08-11-2005 07:28 PM
daza_20
07-23-2005 04:27 AM
Quick Reply: 1971 ford f100 ticking or lifter noise after replacing intake
