2012 Ford Focus SEL Drive does not work, but reverse does
Old 10-19-2022 | 04:44 PM
Danwhite's Avatar
Default 2012 Ford Focus SEL Drive does not work, but reverse does
Help!! When I put the car is drive it won’t move, the engine will just rev. The reverse works fine. Recently my wife’s 2012 Ford Focus SEL has been giving me tons of problems. I just replaced the thermostat housing and the starter. It still has a delay when starting, does not fire right away. Once the car is started a a check engine light is now showing (do not have code). I also have checked all fuses and the fuses are good.
Please help me figure out what this could be.
Old 10-21-2022 | 04:52 AM
raski's Avatar
Read codes first.That may give you some direction for things to check. I believe the transmission forward engagement issue is separate from your engine's drivability issue. Deal with the worst problem first, that being the transmission. On a light note, it may needs maintenance but more likely you are looking at something more serious. I would have the vehicke towed to a good transmission shop for diagnosis. I don't think it's a problem easily solved.
Old 10-22-2022 | 10:38 PM
fusionfan2012's Avatar
My co worker had this problem on his focus. It was a transmission sensor that Ford knows they have a problem with. If you call a ford Service shop they will probably know all about it. He had his fixed under a recall but took a couple of months to get one available
cj0703
08-30-2021 09:56 PM
Kroderi
06-14-2021 08:22 PM
Billfocus
08-10-2016 12:12 PM
Afetcko
09-20-2015 09:48 AM
Focusguy
06-21-2012 11:16 AM
Quick Reply: 2012 Ford Focus SEL Drive does not work, but reverse does
