C4 fit both 2.3 and 5.0 ?
Old 06-02-2010 | 09:33 PM
XLR8's Avatar
Cool C4 fit both 2.3 and 5.0 ?
Just wondering if the C4 that is in my 1988 Mustang LX 4 banger will bolt up to a 5.0 that im building or am i going to have to buy a new Trans. Sorry its a stupid question but some say it will and some say it wont just need to clarify this so let me know your opinion or facts. Thnx
Old 06-09-2010 | 04:33 AM
mmerlinn's Avatar
First, are you SURE that you have a C4 in the 88 Mustang? The last year C4s were made was in 1982.
Second, the answer is both yes and no. However, you don't want to put a 4 banger C4 behind a V8. It will not last.
You either need to put beefier drums in your transmission, or get a C4 from behind a V8. If you use yours, you will also need to replace the front servo. Using a 4-cyl one behind a V8 will destroy your direct band and drum in short order. Finally, you MAY need to change the valve body. If you don't like the shift quality behind a V8, then you wound need to upgrade your 4-cyl valve body or replace it.
shaneandersen
01-15-2014 05:57 PM
travis s
05-23-2013 06:45 AM
drjoe
09-19-2010 05:06 AM
xfactor206
06-18-2007 01:56 AM
Luke 22
05-11-2007 01:42 AM
