Rear wheels not pushing !!
Old 12-17-2013 | 12:51 PM
AMX70's Avatar
Default Rear wheels not pushing !!
I have a 2002 Escape XLT 4x4. Pretty sure rear wheels are not turning in 4x4 mode. Just snowed here and it was horrible on the road. Heard about a viscous coupling and an electro-mechanical switch from reading various forums. Anybody have this problem and fix it without help from the dealer ?? Not much info on this one out there on the web. Any help would be appreciated.
Old 12-17-2013 | 01:33 PM
grindman's Avatar
one way to find out if your rear wheels aren't helping is to jack up the suv off of the ground and support it with jack stands put it in 4x4 and then put in gear and then get out and kook to see if all the wheels are turning at the same time if they're not then you have a problem. keep in mind that you'll need to have all the wheels up off of the ground
Old 12-21-2013 | 11:24 PM
blazed16's Avatar
I have a 03 and just had the exact same issue.
When on hoist and in 4x4 hitting the gas the rear tires would spin however when all tires on the ground there was no power to turn rear wheels.
The couplings in rear diff were bad and had to replace the whole diff.Works like it should now.
jaxbrian
07-14-2009 05:16 PM
anoll62
03-18-2009 03:04 PM
CADenny
07-31-2008 11:24 AM
nickinma
10-23-2006 03:51 AM
mmattice1
02-20-2006 10:30 PM
