trasmission won't stay in park
Old 07-30-2008 | 09:15 AM
carguy_3991's Avatar
Default trasmission won't stay in park
I have a 1964 Thunderbird. It has a Cruise-O-Matic automatic transmission. For some reason it just won't stay in park, even after adjusting the linkage as much as possible. If you have any ideas or knowledge about the problem, please reply. Thanks.
Old 07-30-2008 | 12:21 PM
btexpress's Avatar
Default RE: trasmission won't stay in park
This was/is quite common on older Ford products. You might have worn components in the shifter, such as the detent that provides positive lock in each gear. You need to determine if the problem is in the shift linkage/shifter, or inside the trans. I would suspect something worn in the shifter, especially if it has column shift.
Old 08-15-2008 | 01:33 PM
Thanks Dennis W., I have pulled the transmission, and the column shift selector still won't stay in park so I think that the detent might be my problem.
Thanks,
Chandler C.
digitalincome
02-26-2010 07:45 PM
sparky2
03-25-2008 09:45 PM
2excowner
12-06-2005 05:47 PM
froggie
07-17-2005 04:04 AM
butters417
03-20-2005 11:38 PM
