1993 Aerostar Horn
1993 Aerostar Horn
I aquired a 1993 Ford Aerostar van little over a month ago, and I need help. I got this van in a non-running condition. I got the van running and replaced the gear shift assembly because it was broken. The horn as never worked when I got it. Does anybody know about where the relay is located at for the horn? I have checked the fuse, and the horn itself and they are good. The Airbag light is not on, and I have not checked the cruise control of this van because this van still has flat tires. Before I hooked the battery up on the van, I yanked the AIRBAG Control Module fuse. Any help trying to locate the relay on this van would be very appreciated.
RE: 1993 Aerostar Horn
I found the problem. THe problem is within the clock spring. I took a 1993 Ford Steering column that I got from a junkyard and hooked it up in place of the one thats in the van now, and the horn blows. No I gotta take the airbag off, and the steering column to get to the clock spring to replace.
