2000 Windstar cold heat front and rear
Old 10-29-2009 | 07:51 PM
bochnak's Avatar
Default 2000 Windstar cold heat front and rear
Changed thermostat thinking that was the problem. Heater hoses to heater core(s) are hot. I can see the blend door actuator rotate about 90 degrees behind the radio.
It will puff a bit of warm air when RPM's are a bit higher.
Again, the heat is cold front and rear.
Can the cores be plugged? But then both hoses would not be hot? I would imagine 1 to be cold if it were not circulating.
Thanks, Matt
Use Common Sense
06-25-2016 01:30 PM
jmehan
01-20-2013 07:17 PM
vivalasvegas777
08-29-2012 11:07 AM
1999EBEXP
10-24-2011 10:58 AM
ddbaran
11-29-2006 10:33 PM
Quick Reply: 2000 Windstar cold heat front and rear
