2000 windstar electrical problem
Hi new to this forum, hope someone can help.
When the van is running, everything operates normally. When I remove the key, all the accessories stay on and the headlights and heater fan turn on even though the switches are off. I've swapped all the relays, swapped out the ignition switch and just replaced the front electronic control module (the one on the inside firewall by the fuse panel). The problem is still there. Anyone have any suggestions before I give in and take it to Ford?
RE: 2000 windstar electrical problem
Hey ..hows it goin? Do you still have your old front electronics module? I'm looking for one. Driver side window doesn't work nor does the passenger electric lock. E-mail: M.kubena@comcast.net
wendywoo92
01-02-2008 12:19 PM
