2000 Windstar sqwualling noise with belt off!
Old 10-14-2009 | 11:41 PM
sharphome's Avatar
Default 2000 Windstar sqwualling noise with belt off!
My windstar is making a bad squalling noise. I thought it was the idler pulley so I replaced it. Still did it. Replaced the water pump, still did it and getting worse. I took the serpentine belt off and ran it and it still has that terrible squalling noise and sometimes it about kills the engine. Any suggestions of what could do this with the belt off? I thought it could be a timing belt pulley but found out it has a timing chain!! HELP!!!!
Old 10-15-2009 | 12:21 AM
Welcome to the site..
On the front of the engine you'll see a 'short' looking distributor assy. with a wired sensor on top.. That is the camshaft synchronizer with the CMP (cam position sensor) attached topside.. The shaft inside as well as the housing will run dry from lack of lube and make a terrible chirping/squealing noise.. Place a long extension (or a stethoscope if you have one) extra long screwdriver, round rod ect. and place one end at the base of the synchronizer and the other end against your ear.. If the synchronizer has run dry it will be 'very noticable' with a listening device..
Here's a generic image of what the synchronizer looks like...
Attached Thumbnails 2000 Windstar sqwualling noise with belt off!-aa2157a.gif
Old 10-15-2009 | 08:34 PM
sharphome's Avatar
Thanks, it sure sounds like that is where it is coming from. I hope so, that looks like one of the easier fixes.
Old 10-15-2009 | 08:35 PM
sharphome's Avatar
thanks, that is sure what it sounds like. i hope so, it would be one of the easier fixes it looks like.
Old 10-15-2009 | 10:24 PM
The synchronizer is timed/position sensitive..
If you can accurately 'scribe mark' the base of the synchronizer housing (preferably before removing the hold down) and the block area marked where the housing enters,, and then again scribe the upper housing with an alignment mark, making note or an accurate indication of the upper shaft 'pointing postion' you can usually change it out without any trouble..
Old 09-24-2011 | 09:45 PM
bryon78's Avatar
Default new and need help!!!
i have the same problem and a new one came up while i was trying to remove the cps. there is a metal line that comes out of the water pump above the cps and it is in the way of me pulling it out. there is one bolt holding it in i took it out and now i cant get the line out im stuck please help!!!!
Old 10-14-2012 | 09:45 AM
chillme1's Avatar
Byron78....
1.) Did you get an answer somewhere else? If so, where?
2.) How did you end up fixing this problem?
We are having the same problem with this part squeaking. I haven't attempted to replace myself due to being a novice and not a special tool that others say is needed dur to it being time-sensitive. Thanks for you comments!
Old 10-15-2012 | 01:44 PM
bryon78's Avatar
I had to take off the power steering pump in order to get the cps out. If I'm not mistaken its at the top towards the firewall.
Old 02-12-2022 | 01:59 PM
daddyblaize's Avatar
Default 2003 Windstar
I’m just now changing what appears to be a bad idler pulley. Can anyone tell me a torque spec for that bolt as there’re none in the Chilton’s or Haynes manuals
hardrock96
02-14-2022 06:51 AM
Absolutezer0
02-12-2022 11:32 PM
dmagicman1
06-18-2010 08:59 PM
jwlsale
05-02-2009 03:05 PM
JARS8078
11-16-2008 11:33 AM
