2002 windstar sel
2002 windstar sel
Hey there. I have a problem that i just cant figure out.
2002 windstar sel the engine light keeps coming on. i bought a code reading and it keeps coming up as p0402. I tried unplugging the vacuum to the egr and driving the van for a bit and the lite does not go off. Every once in a while the ligt will go off and on usually around the time my wife fills up, dont know if that is just a coincidence or not.
Just wondering if anyone has any ideas.
Thanks Mike
Thanks Mike
RE: 2002 windstar sel
I would first look for and loose,cracked vacuum lines.If none are found I would suspect carbon build up at the EGR this is a common problem. I would also buy a new EGR gasket a 1 can of gumout. Remove the EGR valve and spray gumout in the passages. Scrape and clean old gasket. Replace gasket then replace the egr. Then disconnect the battery for 5 minutes to clear the code.
linny
04-04-2015 02:13 PM
henryts77
12-04-2013 08:07 PM
